Chris
Odin, Father of the North
Boat Blog
Ordered boat from South Africa...in November...just arrived..:wall what a night mare...but cheap approx 50%..
However, this is a bare boat with no engine etc...
The console and seats are not fitted to the deck, so I have been busy doing the following..
Removed underfloor Fuel tank, and drilled through pre-prepared section to enable cables and fuel pipes to be routed to the engine to make it neat as opposed to running in a big trunk accross the floor..
Fitted the tank back, but it has no fuel sender, so I've ordered a sender and will be fitting and then sealing the floor hatch, then mounting the console and connecting up the various bits of kit...
I've ordered a Honda BF150 2.4 litre Vtech 4 stroke...(£11.5k) with all the gauges and prop etc, the prop has been selected to give 50 knots and 5000rpm...top rpm being 6000...so it should fly...
I should have the lot done by end of August, however, Judi is due to give birth on the 25th Aug so there might be a delay in the build...
