Ninemeister
Ninemeister are proud to be shortly releasing a performance 378mm big brake conversion to fit all 996 GT3/RS which uses a MKII wheel or similar and all 997 GT3's and RS's.
Some more information on the brake discs used.They are designed to be used with the factory 996 MKII GT3 caliper onwards. Kit includes everything needed (rotor, hat and hardware) for a single rotor replacement.
2-piece discs offer better cooling and reduced weight over a one-piece design.Ninemeisters full floating Direct Drive attachment system allows the brake disc to naturally expand/contract on both radially and axially without being constrained by the hub. This helps eliminate disc warping, vibrations and pulsations.Due to the desing of the Brake discs in comparison to the competition we found them to be a lot quiter in operation.
The hat assembly is completely reusable - no need to buy the entire assembly again! All that would need to be replaced is the rotor which is relativley cheap once the conversion has been purchased.
Conversion consists :
2 x 378mm floating rotors
2 x hard anodised machined rotor hats fitted
1 x set of Brake pads specify road or race variants
2 x complete fitting kits
2 x mounting brackets
4 x extra length bolts
12 x squeal shims
2 x spring plates
Calipers and hubs do require modifications at no detrimant to and can be referred back to standard without an issue.
Costings to follow.
any further questions please do not hesitate to contact us.
12 x squeal shims
2 x spring plates
Costings to follow.
