Elite Detailing a Porsche 996 GT3RS White/Blue
Hi all,
This is the first write up I thought I could upload. It's my favourite 996 variant, the GT3 RS. :)
It's owned by Clive off the forum and I was lucky enough to work on it earliar this year..
At the time the GT3RS had completed two consecutive track days and not washed or treated with anything before, during, inbetween or after each trackday.
As you would expect, there was plenty of grime attached to this beauty.
The RS was given one of my normal thorough washes which lasted about 2 hours although I knew that once I had finished drying off the car that there would be plenty more cleaning to do.
Products used listed here:
R222 Total Auto Wash
Zaino Z-7 Show Car Wash
Ultra Safe Drying Towel
Lambswool Wash Mitt
Wheels cleaned with:
R222 High Performance Wheel Gel Cleaner
Meguiars Deep Pile Microfibre Wash Mitt
Boars Hair Wheel Brush
You can see below pictures of the car after the wash. There are still bits of melted rubber all over the car which would need more attention.
The Elite Detailing decontamination process was then performed which basically removed the in bedded foreign properties and extra care was taken on the front venture shield. This took a further 1.5 hours.
One of the products of choice here was:
Zaino Z-18 Clay System
After the decontamination process, as you can see, no more nasty rubber/tar marks:
The car is already looking way better at this point.
The vehicle's paint work was then inspected properly under intense lighting and also measured using depth gauges. In this case I did not need to bring out my microscopes.
After which, the car was masked up and ready for the correction.
Some before shots of the various scratches on the paint and plastics.
Image of me correcting the paint work underneath the RS spoiler.
Some shots of After the paint/plastic correction.
Rear No. plate Corrected:
Lights Corrected:
And now for the After shots of the GT3 RS Detail.
The Car was sealed with:
Zaino Z2 Pro
Zaino ZFX Flash Cure Accelerator Additive
What's this in the reflection? :)
The Roof:
Some more after shots:
The wheels were also sealed with:
Zaino Z2 Pro
The car was finally buffed over again with Zaino Z-8 Grand Finale Spray Seal before put to rest.
Many of the products used in the above detail are available from www.elitedetailer.com .
Work Time on Exterior: 2 days
Thank you for taking a look.
Merry Christmas :tu
Regards
EliteDetailer
WOW !!!!
How much to do a cruddy old MR2 :D
What is the product that you use to get rid of the swirls?
I cannot tell you the exact product I used above but you can still get decent results. I have some products comming next month for all to use so don't worry about that. :tu
Regards
EliteDetailer
lovely job there G,
G has done my car about 6 times thus far, and is both affordable and extremley hard working, unless he has a hangover that is:D
also pretty shit at finding his way home:D
really does go the extra mile:tu
Highly recomend
